T
treez
Here is a LTspice simulation of two identical full bridge SMPS’s. The only difference between them is that one has more transformer leakage then the other.
The secondary diode snubber resistors snub out the leakage inductance ring. Strangely, the full bridge with more leakage inductance gives rise to less loss in the secondary diode snubber resistors. Why is this?
