edge and center aligned data
hulk789
Junior Member level 3
What is the difference between edge aligned and center aligned data.
The difference is a 90 degree phase shift between clock and data for DDR and 180 degree phase shift for SDR.
i.e. clock edge alligned with data chnges or in the middle between data changes when the data is stble
What is SDR and DDR here
SDR - Single Data Rate (at single edge)
DDR - Double Data Rate (at both positive & negative edge)
