actor23
Member level 3
![Member level 3](/styles/images/ranks/dlevel3.gif)
Hello dear edaboard members ;
I'm really tired of getting the same error from proteus
I have 48 to 12 V dc-dc converter pre-design(not completed to apply in real life) with UC2525 PWM regulator chip. My problem is when i am trying to drive to mosfet gates(IRFZ44N) PWM-A(pin-11) is nearly correct but PWM-B(pin-14) is about to gnd.(some 1V peaks when the rise and fall times of PWMA faced). I hope i could explain my problem :S
Here is the proteus design. One thing you should do after open .dsn file with proteus simply push start simulation button then observe digital osciloscope.
Note : The one who do not know how to open .dsn files with proteus(7,8,etc) simply File/Import Legacy Project/ Browse Schematic then import my .dsn file
Edit : My file is directly project file so you don't need to import it just click it two times(in .rar format)
Thanks in advance
Thanks in advance
