abe94
Hi.
I'm designing an open loop voltage controller for my water heater element. I'm planning on using a triac and controlling it using PWM. There is no temperature sensor feedback , just plain AC voltage control. Now , could anyone point me in the right direction regarding this ? I researched AC voltage controllers from various books and have a general idea of the scheme , but get stumped on the finer points. How do I generate PWM trigger pulses ? I suppose it'll be using a 555 timer. If yes , then how ? Also , one of the books said that a capacitive filter was needed at the input to smooth out high switching frequency current drawn from the supply. Another book had exact calculations for the rms output voltage as per the duty cycle employed (Vorms = Vs√k)
where Vorms = output rms voltage
Vs = supply voltage
k = duty cycle
As you can see , my thoughts are pretty much scattered all over the place :-D
Somebody please help me streamline this.
p.s The supply voltage usually hovers around 200 V , give or take 10 or 20 V.
Vs = supply voltage
k = duty cycle
