How to convert bmp file to PCB format for Protel?
SPATAN
Full Member level 2
Full Member level 2
convert picture to pcb
How to convert my logo company (bmp file) to pcb format (protel) ?
Thanks.........
Re: convert picture to pcb
You can try this option:
AutoCAD would be my 1st choice. Import the .BMP into AutoCAD and export a .DXF file that you can import into the CAD tool as 2D-Lines. Then you can convert a closed polygon into copper (if you need to). You can use the "Scale" command to make different versions.
Will it work? Maybe..
    SPATAN
Here are a couple of free utilities that have been around for several years - they work.
Yep. This works, but needs a fair bit of clean up converting arcs. The way Protel imports arcs from DXF is not perfect. However, BMP2PCB works quite well. I'd recommend that.
    SPATAN
try c*re*dra*
Reactions: ragfgha
    V
    ragfgha
