supremekai
Newbie level 2
Hi!
I'm new here, with a basic question: I would liek to join, on the layout, the drain of two transistors that share the same drain
Here are the two transistors:
Can the drains be joined this way (is it correct?):
I've just moved one of the transistors in order to allign the contacts of the drain of both transistors, as shown above.
Is the method used correct or should I create, for example, an unique substract for both (how can I do it?) of them?
Best regards :thumbsup:
