blade88
Junior Member level 2
In adaptive coding and modulation (ACM) the modulation and coding change, according to the channel conditions.
As I understand, the useful information throughput is changed: when the channel is "bad", the coding bits increase and when the channel is "good", the coding bits decrease.
However, does the bit rate change?
thank you
thank you
