JTAG TAP controller TDO pin
sunidrak
Full Member level 1
Full Member level 1
Bengaluru, India
I am working on JTAG TAP controller in which TDO pin is a tri state . What is the advantage of Tri state TDO pin in TAP controller plz expalin I need badly
maybe to allow bypassing a faulty part in a JTAG chain to allow further testing comes to mind. Then you can jumper TDI to TDO of that part if it's not working correctly.
You can drive multiple taps and have them share to TDO pin. You do need to be able to select one tap at a time.
John Eaton
