matrixofdynamism
Advanced Member level 2
ASICs and FPGAs that have a lot of power rails usually contain the sequence of power up/down as part of specification. This includes the order in which the rails should be powered up/down and also the time minimum pause between powering up/down successive rails.
Why do we need such a sequence, what are its origins?
What will happen if this sequence is not followed for power up?
What will happen if this sequence is not followed for power down?
