Low cost low frequency oscillator
Jester
Full Member level 6
Full Member level 6
I have the need for a low frequency (say 1kHz) oscillator as follows:
- Really inexpensive
- Reliable start-up -40 +90 deg C
- 0-5V output @ <10uA
- Accuracy 20%
- Duty cycle 25 - 75%
- power source; +5Vdc
The tried and true 555 circuit is pretty cheap: $0.44@qty10, or $0.22@qty100 (Digi-Key pricing)
Does anyone have a cheaper or more elegant solution?
How about a single-gate Schmitt-trigger oscillator?
Digikey has 74AHCT1G14SE-7DITR-ND at $0.0425/3000
Reactions: Jester
    Jester
'HCT14G may be best price readily available.
But do you need to guarantee 20% accuracy with a 10% supply over wide temp with what tolerance cap?
Reactions: Jester
    Jester
Actually for this application, the frequency is not critical at all, I can live with 50% accuracy.
I like the proposed solution, not only is it less expensive, it uses a smaller package (SC-70 vs. SOIC8) and one less component.
Thank you.
The ordinary 555 with a 5V supply has an output that is a minimum of only 2.75V if it has no load. The 555 draws a fairly high current all the time.
any comparator should do. and three resistors and a c. plus a c for vcc decoupling.
it is very stable in time and has good stability on VCC change. Temperature drift is more a problem of the used C.
I don´t know if this solution is cheaper than others.
