corpuralx
Junior Member level 3
![Junior Member level 3](/styles/images/ranks/clevel3.gif)
Good Day,
I would like to ask for help in troubleshooting my exercise experiment. I was trying to show a message in my 8x2 LCD display LM016L. The message in 1st line should be " R2K Technology " and in 2nd line is " MCU - Trainers ". The 2nd line won't show but the first line showed however with incorrect/random characters. The proteus also shows hundreds of errors saying "Attempted to write after reading a single nibble". I searched the web advising to add delays, i did but still the same. I noticed on the part of code calling "QUICK:", when i change R5, #100 to #1, the LCD shows R2K Tecf pE=Ew something like that, better than the previous one but still no 2nd line message. What part of code do you think would be the problem guys? In what line of code is the fault and the supposed correct right line of code? Thanks in advance.
Clock Frequency,
Crystal Oscillator: 11MHz
PIC: 11MHz
LCD LM016L: 250kHz
Here's the schematic:
![Screenshot_4.jpg Screenshot_4.jpg](https://www.edaboard.com/data/attachments/51/51625-d78ac23c12251317443b1653493d0aad.jpg)
Here's the code:
Clock Frequency,
PIC: 11MHz
LCD LM016L: 250kHz
Here's the code:
;PROJECT NAME: MYEXPRT10A ;
;FILENAME: EXPRT10A.A51 ;
P1 EQU 090H ;P1.0
P1_1 EQU 091H ;P1.1
P3 EQU 0B0H ;P3.0
TL1 EQU 08BH
TR1 EQU 08EH
TF1 EQU 08FH
TMOD EQU 089H
TH1 EQU 08DH
SP EQU 081H
RS1 EQU 093H ;P1.3
EN EQU 0B2H ;P3.2
RW EQU 0B7H ;P3.7
BUSY_FLAG EQU 097H ;P1.7
CLR_DISP EQU 01H
RET_HOME EQU 02H
DISP_OFF EQU 08H
DISP_ON EQU 0CH
CURSOR_ON EQU 0EH
BLINK_ON EQU 0FH
CODE_2X7 EQU 28H
LINE1_START EQU 080H
LINE2_START EQU 0C0H
ORG 00H
JMP START
;;;;;;;;;;;;;;;; START INITIALIZATION;;;;;;;;;;;;;;;;;;;;;;;
START:
CLR P1
CLR P1_1
CLR 093H ;P1.3
CALL DELAY_15MS ;DELAY ATLEAST 15MS
CLR EN ;LCD CONTROLS TO LOW
CLR RS1
CLR RW
MOV A,#03H ;1SEND CODE TO LCD
CALL SEND_2_LCD
CALL DELAY_5MS
MOV A,#03H ;2SECOND CODE TO LCD
CALL SEND_2_LCD
CALL DELAY_160US
MOV A,#03H ;3SECOND CODE TO LCD
CALL SEND_2_LCD
CALL DELAY_160US
MOV A,#02H ;SEND 4 BIT ENDTRY MODE
CALL SEND_2_LCD
CALL DELAY_160US
MOV A,#CODE_2X7 ;SEND 16X2 CH 2 LINES
CALL SEND_COMMAND
MOV A,#DISP_ON ;TURN ON DISPLAY
CALL SEND_COMMAND
MOV A,#CLR_DISP ;CLEAR COMMAND
CALL SEND_COMMAND
;;;;;;;;;;;;;;;;;;;;INIITIALIZATION;;;;;;;;;;;;;;;;;;;;;;;;;;
DISPLAY_FIRST_LINE:
MOV SP,#07
CALL QUICK
MOV A,#LINE1_START ;FIRST LINE
CALL SEND_COMMAND
MOV DPTR,#MESSAGE1 ;LINE1 MESSAGE
MOV R7,#16
DISPLAY_FIRST_LINE_LOOP:
;CALL QUICK
CLR A
MOVC A,@A+DPTR
CALL SEND_DATA
INC DPTR
DJNZ R7,DISPLAY_FIRST_LINE_LOOP
DISPLAY_SECOND_LINE:
CALL QUICK
MOV A,#LINE2_START ;2ND LINE
CALL SEND_COMMAND
MOV DPTR,#MESSAGE2 ;LINE2 MESSAGE
MOV R7,#16
DISPLAY_SECOND_LINE_LOOP:
;CALL QUICK
CLR A
MOVC A,@A+DPTR
CALL SEND_DATA
INC DPTR
DJNZ R7,DISPLAY_SECOND_LINE_LOOP
CALL HALF_SEC_DELAY ;DISPLAY HALF A SECOND
BLANK_MESSAGE:
MOV A,#CLR_DISP ;CLEAR LCD DISPLAY
CALL SEND_COMMAND
CALL HALF_SEC_DELAY
SJMP DISPLAY_FIRST_LINE
;;;;;;;;;;;;;;;LCD RELATED ROUTINES;;;;;;;;;;;;;;;;;;;;;;;;;;
SEND_2_LCD:
SWAP A
SEND_CODE:
SETB EN
ANL P1,#0FH
ORL P1,A
CALL QUICK
CLR EN
RET
SEND_COMMAND:
CALL READY ;BUSY FLAG
CLR RS1
CLR RW
JMP SEND_ROUTINE
SEND_DATA:
CALL READY
SETB RS1
CLR RW
SEND_ROUTINE:
ORL P3,#00111000B
MOV R6,A
ANL A,#0F0H
CALL SEND_CODE
MOV A,R6
SWAP A
ANL A,#0F0H
CALL SEND_CODE
RET
READY:
SETB BUSY_FLAG
CLR RS1
SETB RW
KEEP_POLLING:
CLR EN
CALL QUICK
SETB EN
JB BUSY_FLAG,KEEP_POLLING
RET
;;;;;;;;;;;;;;;;;DELAYS;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
DELAY_15MS:
MOV TH1,#0CAH
MOV TL1,00H
ORL TMOD,#01H
CLR TF1
SETB TR1
JNB TF1,$
CLR TF1
CLR TR1
RET
DELAY_5MS:
MOV TH1,#0EEH
MOV TL1,#00H
ORL TMOD,#01H
CLR TF1
SETB TR1
JNB TF1,$
CLR TF1
CLR TR1
RET
DELAY_160US:
MOV TH1,0FFH
MOV TL1,60H
ORL TMOD,#01H
CLR TF1
SETB TR1
JNB TF1,$
CLR TF1
SETB TR1
RET
HALF_SEC_DELAY:
MOV TH1,#0DCH
MOV TL1,00H
ORL TMOD,#01H
CLR TF1
SETB TR1
MOV R7,#180
DELAY_CONT:
JNB TF1,$
CLR TF1
MOV TH1,#0DCH
DJNZ R7,DELAY_CONT
CLR TR1
RET
QUICK:
MOV R5,#100
DJNZ R5,$
RET
;;;;;;;;;;;;;;;;;LOOK UP TABLES;;;;;;;;;;;;;;;;;;;;
MESSAGE1: DB ' R2K Technology '
MESSAGE2: DB ' MCU - Trainers '
END
