For small current relays and cheap circuit I use transistors to drive the relay from the PIC ports.
A NPN general transistor (BC547) can be used to drive up to 100mA coils. More than this you can use a darlington transistor or use a MOSFET (drivered by bipolar transistor).
Vcc
___!___
_ !
1N4007 Λ Rly coil
!______!
C
PIC port >--Resistor----B NPN transistor
E
GND
Just remember to use 1N4007 diodes to Back Voltage generated by the coil.
The relay is activated by high logic level (4.7V in the PICs). The resistor is calculated:
R = (4.7V - Vbe)/Ib
Ib = Ic / transistor beta (Ib cannot be greater than 25mA)
Ic = current in the coil
Vcc must be at less the coil voltage + Vce saturation
The PIC I/O ports can source or drain up to 25 mA, so they can be connected directly to small reed relays (use the diodes reversed).
