In need of planar EM simulation manual for Ansoft Designer 2
tketke2002
Ansoft designer 2.0
Does anyone have the user manual of this simulation software? Looking for the planar EM simulation manual.
tony
Re: Ansoft designer 2.0
Contact your local Ansoft technical support. They should be able to provide you with a tutorial or getting started guide.
or try the link below:
Regards,
Itai
dear Itai,
I have both from the local distributor but i wonder if there is not a more elaborated user manual available... I can not find any at the OTS from Ansoft...
thanks for answering,
tony
Ask your local distributor to contact the French office.
I think they will be able to provide what you are looking for.
Itai
Dear Itai,
I already asked the French distributor but they tell me that there is no User manual available...
tony
Ansoft is known by their bad tutorials. So, you have to do much of stuff on your own. However, they have good support, so if you tell them your problem, they can largely help.
Ansoft designer 2.0
I have one. Enjoy it!
    tketke2002
