SPDT relay footprint for Orcad
zawminoo
Full Member level 1
Hi Everybody,
I have no footprint for SPDT relay footprint for Orcad.
I searched in google and in this forum. I get some footprint files but their file extension are MAX , fp and etc.
At my orcad, footprint files extension are bra and psm. I don't know how how to change these file extension. So, Please help me and give relay footprint files for Orcad files with extension are bra and psm.
Thankyou!
There are also free and paid for tools to create IPC7351A footprints. Look for EDA Builder, Ultra Librarian or PCB Libraries.
you can create the new foot print in lay out plus or just use save as and Save the MAX file to .lib or other format you have available.
Find the datasheet of that relay and follow the LAND PATTERN DATA dimension or FOOTPRINT dimension. Create your own library, it will give you a confidence to create new and more library. All the best.
Tee relay footprint has only about 5 pads on it, they are usually on a 0.1" grid too - they are simple to make.
Learn how to make them in your package.
Then you'll not have the delays & problems with not having the right footprints.
