neazoi
Advanced Member level 6
Hello, I have an idea which I would like to discuss with you.
I wanted to clean up the mains voltage of any waveform impurities, spikes etc.
One could use a transformer and PSU to convert to DC and then feed this to a sinewave inverter, but I have thought of another way.
Two motors from a microwave oven blowers (brushless moving magnet) will be connected back to back. One motor is used as a motor and the other as a power generator. The motor moves the power generator and produces an ultra clean sinewave, because the motor motion (and the flywheel effect drom the moving magnets weight) cannot respond to sudden mains spikes and noise.
I hope the motor can operate at 50 times/sec as it's label states 220v 50Hz.
My idea can be improved even further. One could connect the motor and the generator using a set of gears. Depended on the gear size, the output frequency of can alaso ghange. For example one could convert 50Hz to 60Hz. However the voltage output will also change and this can be compensated with external transformers.
How do you find my ideas, any comments are appreciated?
Do you know of any such commercial product?
