israel_Y
- Joined
- Feb 8, 2010
- Messages
- 34
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- The Netherlands
- Activity points
- 1,534
can i connect an inverted opamp output (0 to -3.3V output) to ADC of microcontroller (stm32) configured in differential mode. From The MCU datashet it says [In differential input mode, the analog voltage to be converted for channel “i” is the difference between the external voltage ADC_INi (positive input) and ADC_INi+1 (negative input).]
So i would be connecting gnd/Vcm=0 of opamp to ADC_INi and the negative opamp output to ADC_INi+1. will this work.
Thank you in advance for your time and answers.
