Infrared emitter and detector LEDs
wat007
Junior Member level 3
Please give me partnumbers of common IR emitters and detectors please? Those that can be use in toilet for automatic flushing. Thank.
Regards,
wat007
You can use PIR sensors for this application
Reactions: wat007
    wat007
Hi Mukesh.k.s but i am looking for an active one which i think is a bit cheaper because we do not need a lens/cover.
The application of this also can be indoors or outdoors which makes the active IR sensors a better option to filter out infrared of foreign objects like the sun by modulating the emitter. Please correct me if I am wrong.
And i need to know common partnumbers of thses sensors. I tried using TCRT5000 but very limited distance range (30mm max). Do you have some alternatives?
You'll find optical proximity sensors with larger range e.g. at Silabs.
Reactions: wat007
    wat007
Hi FvM,
Thanks. What is the main factor of the IR emitter's range? Is it the forward current?
Forward curent and beam angle plays a role, more inportant is the receiver topology. For distances above a few mm and ambient light immunity, you'll generaly go to modulated (pulsed) light.
Reactions: wat007
    wat007
