curious#01
Newbie level 2
Hi everyone,
I am tryng to design a buck converter. The gate of the n-channel MOSFET of the buck converter is connected to the pwm pin of a microcontroller. I have a few doubts regarding this:
1. What is the difference between normal mosfets and power mosfets. How do I decide which type of mosfet to use in my circuit?
2.When can I directly connect the gate of the mosfet to the pwm pin of the microcontroller?(I was planning to use stm32f series microcontroller which has a pin voltage of around 3.3V)
3.If direct connection is not possible, what kind of gate driver circuit should be used for the mosfet to work properly?
Would be highly thankful if anyone could help me out.
