I was wonderign if the SA602 (or SA612) can be driven with an external square wave oscillator instead of a sine wave.
You can drive the SA602 with sine or square wave LO signal, and it will work. Only make sure the LO power does not exceed the specification.
As such signal contains harmonics, the converter will respond to harmonics, too. If this is not desired, use band-pass or low-pass filters in RF and LO inputs.
Thanks. So in a square wave, if I put an LPF it will become a sinewave, since harmonics are filtered?
