dizgah
Member level 5
hi every one
usually in embedded applications which one is preferred ?
Memory cards like MMC or SD/micro SD or flash ICs?
as you know Memory cards has more capacity than flash ICs but usually we do not need more than some hundred Mega bytes,altough Flash ICs usually dose not have memory space more than some Mega bytes too.
then whats your solution ?
& which brand do you use in your designs?
best wishes.:-D
Mahmoud
best wishes.:-D
Mahmoud
