adnan012
Advanced Member level 1
I want to design an On/OFF solid state switch to drive a 5 to 6 HP Dc Motor (water pump).
The input voltage range from 130 to 300v DC.
The purpose of this switch is to start the motor after sunrise (when there is enough power available to drive the motor to get minimum possible water flow) and switch off the motor in the evening when solar panels power drops to a certain level.
I need suggestions.
I need suggestions.
