LAORUAN
Newbie level 5
what does these sentence mean?
Input delays can already include clock source latency. By default the clock source latency of the related clock is added to the input delay value,but when the -source_latency_included option is specified, the clock source latency is not added because it was factored into the input delay value.
If -source_latency_included option is used, it means I should add the source latency into input delay or I should not add the source latency into input delay(Timequest will add add the source latency into input delay)?
Any help will be appreciated. Thank you.
