eng.amr2009
Junior Member level 3
Hi guys,
Summary of Q's
In cadence RC, upon clock gating, clock multiplexing or clock division, should I define the output clock from these modules in the synthesis script ?
Detailed:
I implemented a module with multiple clock inputs which I need to synthesize.
say I have clk1_in & clk2_in input to a clock mux. The mux output is clk_mux_out. Then clk_mux_out is gated to generate clk_mux_g.
Do I have to define all these clocks in the synthesis script ?
What I do is define all these clocks, assign them the same domain and clock frequency.
In case I want to make the constraint of one of these clocks tighter than others for as margin is it harmful regarding the clock to clock edge ?
In case I multiplex two clock of different frequencies, do I need to constraint the mux output to the fastest clock ?
I'm stuck at this
Summary of Q's
Detailed:
I'm stuck at this
