application of Antenna on these frequencies 10.16GHz 11.33GHz 13.31GHz 15.43Ghz ..
vishal_sonam
Full Member level 3
Full Member level 3
Hello
Can anybody tell me about the application antenna on these frequencies.10.16GHz, 11.33GHz, 13.31GHz , 15.43Ghz , 16.40GHz, 18.745GHz, 21.820GHz, 23.23GHz, 27.91GHz, 32.005GHz.
My antenna is producing these resonant frequencies so I need to know about their applications on these frquencies.
thanks
Hi vishal_sonam,
Depending on the type of antenna you have designed, if its a high gain antenna, you could use 32GHz for satellite communication purposes. I'm designing an array antenna, targeting at 30GHz frequency range with a minimum gain of 5dB, although its a reflect array( has the highest gain). In addition most of the satellite communication applications take place at the lower frequencies of the millimeter-wave range.
Hope this helps!
Antenna application is defined by the system in which it should function. If your antenna "resonates" at so many frequencies, it looks like a poor device useful for nothing.
do not forget about polarization, at satellite range linear polarization may be a problem.
at this range microstrip monopole without ground plane is better i think...
and if you obtained this result only by simulation it may be far away from reality, maybe true at one-two frequencies.
