Error: Zero-time oscillation in node
ERIC.C
Newbie level 2
Newbie level 2
Dear Friends,
Can someone please advice what's wrong with my code? I found this error when I run the functional simulation. Error: Zero-time oscillation in node
Below is my code.
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity Lab6_Synchronous_5bit_enable_up_down_counter is
port ( Clock, Enable, UpDn, Rst :in std_logic;
       Output                   :out std_logic_vector(4 downto 0));
end Lab6_Synchronous_5bit_enable_up_down_counter;
architecture Synchronous_5bit_enable_up_down_counter of Lab6_Synchronous_5bit_enable_up_down_counter is
signal count:std_logic_vector(4 downto 0);
signal s : std_logic;
begin
s<= Enable and Clock;
process (Clock, UpDn)
begin
if rst = '1' then
count <= "00000";
elsif s='1' then
if UpDn = '1' then
count <= count+1;
else
count <= count-1;
end if;
else
count <= count;
end if;
end process;
output <=count;
end Synchronous_5bit_enable_up_down_counter;
You forgot the "if rising_edge(Clock)".
Edit:
I recommend that you start using the numeric_std library instead of std_logic_unsigned.
This means that "count" will be of type unsigned instead of std_logic_vector.
Reactions: ERIC.C
    ERIC.C
What you coded is a latch that is enabled by your gating circuit "Enable and Clock".
What you need is a flip-flop that activates on the rising edge of clock. In addition, you do not want to use a clock gate ("Enable and Clock"), but instead want to do a data path enable. The following is the template you need.
8
9
10
process (rst, Clock)
begin
  if rst = '1' then
    count <= "00000";
  elsif rising_edge(Clk) then
    if Enable ='1' then           -- note enable coded separate from clock to ensure synthesis tool support
      -- Do your counter stuff here
    end if ;
  end if;
end process ;
Note, if you have a proper flip-flop, you do not need the final else with the assignment "count <= count".
Reactions: ERIC.C
    ERIC.C
Hi std_match:
Thanks for your input. After add in "if rising_edge(Clock)" I'm able to run the functional simulation but I can't get the result for timing simulation. There output is 0.
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
library ieee;
begin
begin
if rising_edge(clock) then
if rst = '1' then
count <= "00000";
elsif s='1' then
if UpDn = '1' then
count <= count+1;
else
count <= count-1;
end if;
else
count <= count;
end if;
end if;
end process;
output<=count;
you didn't take synthworks advice and still have the following in your code:
elsif s='1' then
This is a race condition in the code between the clock edge and generating an enable in the code based on the clock and the Enable signal. Scheduling wise I think the rising_edge(clock) happens before the transition on s is ever seen.
You also have UpDn in your sensitivity list, which it shouldn't be as it's inside the rising_edge(clock) if statement.
Maybe you need to go back and read up on how to code a process.
Reactions: ERIC.C
    ERIC.C
