chuckey
Advanced Member level 6
The .51 ohm resistor sets the maximum current, the volt drop across it due to the output current causes the transistor to conduct more and bring the output voltage down. Putting a resistor in series with output reduces the output current too much. You are looking for a voltage drop across the .51 of .7V at your max current, so make it .7/.32 ~ 2 ohms.
Frank
Frank
