can not show the connection in Altium
alibarghi
can not show the connection between pads?
I tried using the option "View/Connection/Show All" But still the problem persists :sad:
Now what do I do?:cry:
Verify that you have the "default color for new nets" system color (layer) enabled. Use the "L" keyboard shortcut (or Design > Board Layers & Colors menu) and look in the lower right quadrant under system colors for the "default color for new nets" option and make sure it's checked. That is the likely solution to your problem.
Thanks your reply
That worked.:p
Thank you very much
