Getting Started with Arduino UNO in Assembly Language
Eshal
Advanced Member level 1
Nowhere :)
Hello to all experts who have experience in 8051 :)
My question is only for those who have read "The 8051 Microcontroller by M. A. Mazidi"
If you have read this book then you will know how easy it is and like a child he taught everyone through this book. Now, kindly suggest me the same book for Arduino UNO with programming in Assembly Language. Thank you all.
Isn't good that I search the whole website for just to know one thing instead I ask it with an expert ?
I didn't found anything about programming Arduino in assembly. But I have heard from others that we can do it in assembly too. But I didn't find any book on this. Do you know??
I think it is better to start avr using Assembly since Arduino is product of avr ( I mean chips )
Reactions: Eshal
    Eshal
is there any difference between arduino and avr??
i have checked it out but didn't find any assembly language guide.
Reactions: Eshal
    Eshal
Ohh I see. AVR means the controller which is used on the Arduino board like ATMega168P, etc. Right?
And Arduino itself a whole board having input and output connectors, ADC, Jack, LEDs, right????
The essence of the Arduino boards is that it integrates directly with the Arduino C++ IDE using the Mega chips bootloader via its usb to serial link.
There is no reason why you cannot create your assembly program and burn it directly to a mega chip or using a serial link if you have programmed in a bootloader.
Just that you need to add a few basic parts to the Mega like a crystal, psu and a programmer.
Though I have not tried AVR Assembly ( only Pic assembly) and do not know of the author you mention, the first place I would look for Assembly help is the AVR site which show a lot of detail and practical working examples as shown on the other sites shown below.
http://www.atmel.com/Images/doc1022.pdf
http://www.avr-asm-tutorial.net/avr_en/
http://sites.google.com/site/avrasmintro/
Dear wp100...erasing boot loader, can we use all arduino boards as normal avr development board but we need avr programmer then we can simply program assembly language using avr studio
Boards like the UNO use a USB to Serial chip to communicate between the Arduino IDE and the Mega328 chip USART pins; so that can really only load a .hex file via the serail bootloader.
However if you look at the UNO or similar boards you can see there is a ICSP header on there should allow you to program the .hex file into the mega328 via a separate programmer.
As for ICSP programming the UNO from AVR Studio - have not used it, but was told Studio can only connect / interface to the AVR Dragon programmer, so using a cheap USBISP type AVR programmer you would still have to manually pick out the .hex file from Studio.
Worth a look in the Arduino site and forum as I believe the earlier Duemilanove boards could be modified to program without the bootloader..?
