[SOLVED] equivalent of 74HCT14 for one input.
vikky
Full Member level 3
Full Member level 3
Hi all,
My circuit had 74HCT14 because i had to drive 5 inputs.Now i have only one input to drive so can anyone suggest how to drive the input without using 74HCT14?
You need to tell us what is the Driving device, eg a Pic micro port ? and what is the Driven Input device ?
Also do you need the Inversion a 7414 produces ?
Hello sir,
Thanks for your response.Yes i want the same functionality since code is not going to change.I am attaching the part of the schematic.Input is from a I/O port from a rabbit core module.With reference to the attached schematic i am just going to use PG1 and remove others.Thank you.
do you mean "single gate logic" like 74HCT1G14?
Yes sir,thanks for your help.Let me try to source it.
Yes sir.Thats what i meant since i have only one input.
I think this IC may suit my purpose.
http://www.jameco.com/Jameco/Products/ProdDS/1387307.pdf
For simplicity why change from the 74..14 chip ?
If its being driven from a digital output of that micro it should not need to be a Schmitt Trigger device so any standard inverter chip like 7404 should work fine.
Alternatively you should be able to drive it directly from the micro if you change / invert the output condition of that port.
Reactions: vikky
    vikky
With little change in the code i did manage to drive it directly.Thank you wp100 and thanks all for your suggestions.
