mrln55
Junior Member level 2
I'm building a series of octave signal sources covering 25-400Mhz and the signal chain includes series combinations of couplers and attenuators. Conceptually, I would like to eliminate the coupler and use the shunt leg of a discrete resistor tee attenuator to sample the signal for input to a PLL, and to a power detector at the output. A reversed coupler would still be used at the output for measuring power reflected from the load. The off-the-shelf surface mount couplers and attenuators have published typical performance data that is quite good, but the specified performance is usually inferior to the typical performance data. I am considering using .1% thin film resistors in a 402 or 603 package to replace the SMT couplers and attenuators on .062" FR4 (nominal k=4.3). Although the discrete resistor approach has the benefit of greater freedom in selecting the degree of coupling and attenuation and a reduced overall footpriint, I am not sure how much impact the resistor parasitics will have, or if there are other problems in matching. Any comments or suggestions?
