graphene
Full Member level 2
I now want to place the input/output signals perfectly into a particular pin as described in my circuit plan. I am using Spartan-3 XC3S400, XIlinx ISE 14.7. As shown in figures below, I need the pin 67, 65, 64 to be assigned for particular scalar ports.
However, when I use my Planahead 14.7 is shows me a layout of IO planning but doesnt specify the pin numbers but rather shows them as W22, R1, C22, etc. In the IO planning layout I have A-Y, AA, AB in column and 1-22 in row. Now how do I find the pins 67, 65, 64 ? Any suggestions?
I have my VHDL FPGA design tested. I have also set timing constraints.
