ATmega AVR microcontroler programming
Junus2012
Italy
Dear friends
I would like to start learning about ATmega AVR microcontrollers, I would like to program with C , I am going to buy the Ardunio 2560 kit
please friend i need your suggestion about books or materials i need to start in programming
thank you in advance
regards
Well Arduino really isn't C, it has a basic bootloader built on top of it (but you can do C programming instead). If this is your first language I would do any tutorials to get the structure down of C and to figure out the different data types and flow. I believe if you search on Amazon, there are numerous books for AVR C programming. I don't own any so I don't have any to recommend. What IDE do you plan to use for programming?
I think the definite guide book for program C on AVR is
Embedded C Programming and the Atmel AVR
written by RICHARD BARNETT, LARRY O’CULL, SARAH COX
Well, I did not read this book. This book was not pressed in my country.
If you think it is easy to start with AVR using this book, then it is OK.
The book I recommended also gives a introduction for C language, which is good for beginners not familiar with C.
I find an open course that focuses on Atmel's microcontrollers and development hardware. The course deals with microcontrollers as components in electronic design and embedded control. I hope this can help you learn embedded system and AVR microcontroller programming.
1) Design with Microcontrollers
