Weighing Scale application using NAU7802 and 8051
RohanDey
India
I am trying to develop a weighing scale application using 8051 and NAU7802 ADC. So far I am able to get the counts from the ADC.
I am using a 10Kg, 2mV/V Loadcell, with 5V excitation voltage.
For the ADC I am using a reference voltage of 4.5V. The ADC is a 24-bit one.
My question is, from the ADC counts, how do I convert them to weight values in Kg?
The counts which I retrieved from the ADC, at PGA gain = 1 are:
1. At no load - 16,000
2. At 1Kg load - 19,080
3. At 2Kg load - 22,170
Please help..
I assume your sensor gives linear output. I hope you understand this.
No load = 16000
@ 1 Kg = 19080
@ 2 Kg = 22170
19080-16000 = 3080
22170-16000 = 6170 (6170 / 2 = 3085, approx 3080)
Post datasheet of sensor.
Vref = 4.5V
Resolution is 24 bit = 16777216 counts
0 to 16777215
If your sensor gives linear output then
16777215 - 16000 = 16761215
4.5V = 16761215 raw ADC value
x = 3080 = 8.269090277763277e-4 V = 1 Kg
3080 = 1 Kg
16761215 = y Kgs
y = 5441.952922077922 Kgs
With 4.5V Vref for ADC, 5441.952922077922 Kgs can be measured.
16761215 * z = 5441.952922077922
z = 3.246753246753247e-4
1/z = 3080 = (19080 - 16000)
WeightInKgs = (RAW_ADC_VALUE - 16000) / 3080;
If RAW_ADC_VALUE = 22170 then
(22170 - 16000) / 3080 = 6170 / 3080 = 2.003246753246753 Kgs.
That's a brilliant explanation. Thank you very much.
What happens if I change the Loadcell?
Here we are calculation the weight from the equation:
WeightInKgs = (RAW_ADC_VALUE - 16000) / 3080, where the value 3080 comes from testing different loads using this particular Loadcell. If I change the Loadcell to a 50Kg, 2mV/V one will this value (3080) be same?
What is the 50 Kg max Loadcell's o/p without load and with 1 Kg load?
Yes, it will be same. 5000+ Kgs I mentioned is with 2mV/V sensor and 24 bit ADC. The max value the ADC can show is 5000+ kgs but if your Loadcell range is 0 - 50 Kgs and 2mV/V then for 50 Kgs the adc value will be 3080 * 50 = 184800.
No load = 16000 and 50 Kgs = 184800
Actual value for 50 Kgs will be 184800 - 16000 = 168800.
(168800 - 16000) / 3080 = 49.61038961038961 approx 50 Kgs.
