diarmuid
Full Member level 2
- Joined
- Aug 4, 2011
- Messages
- 143
- Helped
- 10
- Reputation
- 20
- Reaction score
- 9
- Trophy points
- 1,308
- Location
- Dublin, Ireland
- Activity points
- 2,429
As part of a larger block I am working on, I need to insert a simple common source amplifier.
I am using an NFET as the driver biased up using a cascoded PMOS current source.
At typical corner I bias the amp to achieve the required output DC bias. However, across
corners the output DC bias goes bananas!
For example:
- at Fast N/slow P corner the output DC bias drops, pulling my NFET driver out of saturation.
- at slow N/fast P corner the output DC rises, pulling the PMOS current source out of saturation hence starving
the amp of any current.
Needless to say, at both corners my nominal gain (42dB) goes to near zero.
Does anyone have an idea as to how to bias a common source amp such that it will hold its gain close
to its nominal value across corners?
Any input greatly appreaciated!
Thanks,
Diarmuid
For example:
Thanks,
Diarmuid
