[SOLVED] Designing Automatic Voltage Stabilizers
Re: Voltage Stabilizer using microcontrollers.
under over voltage setting is fix in hex file.
you don't need to set under over voltage setting according to that hex file.
Hi
I think you will find all the information if you study below all the post. Further we will help you more, when you described your details.
How can I change the delay 5Min and 3Sec. Thanks Alotzzzz,
How can I change timmer to 5Min and 3Sec; Thankzzzzz
do you have static voltage regulator design (SVR) ??
Re: Designing Automatic Voltage Stabilizer
Mr. irfan ahmad
I liked the circuit developed by you using pic16f676
But why when Brutus tried to operate at low voltage stop all
relays????
I ask you to help me.
Thank you my friend
sorry irfan.
proteus 8 professional.
look at this my friend
all relays Works at 2.3v
and look at this
all relays off Except 9 at 1.6v
this software is basically PID controller.
software read output voltage and check if these are less or grater then set points .
after checking decide either on any relay or off.
for checking of this software you should require a variable transformer to change input voltage.
proteus does still not have variable AC voltage source or maybe i don't know about it .
if anybody can solve this matter then simulation will possible.
Do you have mikro C code irfan Please
Thank you jayanth.devarayanadurga
Can you post the Source code for the Circuit
Add my voice to srenjis
Thanks for your help irfan
This is source code.
compiler is ccs pic c . THIS COMPANY https://www.ccsinfo.com/content.php?page=compilers
              ----v----
       +B < 1 |       | 14 > -B
       A5 < 2 |       | 13 > A0 > AN0     adc input
       A4 < 3 |       | 12 > A1 > AN1     relay1
       A3 < 4 |       | 11 > A2 > AN2     relay2
       C5 < 5 |       | 10 > C0 > AN4     relay3
       C4 < 6 |       |  9 > C1 > AN5     relay4
 AN7 < C3 < 7 |       |  8 > C2 > AN6     led
/////////////////initialization/////////////////////
   #include	<16f676.h>
   #device     adc=10
   #use        delay(clock=4000000)
   #fuses      intrc_io
   #fuses	   NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR
/////////////////////pins  lables///////////////////
   #define     relay1   pin_a1      //main   change
   #define     relay2   pin_a2      //main   change
   #define     relay3   pin_c0      //outputchange
   #define     relay4   pin_c1      //output on off
   #define     led      pin_c4      //
   #define     sw       pin_a3      //active low
   #define     low_limit      1550  // limit for low  voltage
   #define     high_limit     2450  // limit for high voltage
   #define     low_ok         2100  // value for main low  function compleate
   #define     high_ok        2440  // value for main high function compleate
///////////////////labling of syntex////////////////
   #define  on       output_high
   #define  off      output_low
   unsigned int32 main_v=1000,count;
   unsigned int8  step=1,time=0,x;
   int1           fault=0;
   unsigned int8  delay=30;
   void adc_read  (void);
   void relay_Set (void);
   void main_high (void);
   void main_low  (void);
   void initialize(void);
   void  start_up (void);
/////////////////////timer1 isr//////////////////////
   #int_timer1
   void  timer1_subrutine(void)
   set_timer1(65536-62500);         // after 0.5S interrupt will rise
        time++;
         output_toggle(led);
            if (((time>delay)||(input(sw)==0))  &&  (fault==0))
                  time=0;                          // for next round
                     on(led);
                        on(relay4);
                        disable_interrupts(int_timer1);
                            disable_interrupts(global);}
   void  main()
   initialize();
   WHILE(1)
       start_up();
////////////////////normal loop///////////////////////////////
   do
   for(x=0; x<20; x++)                               //loop to perform voltage stabalization function
                                                     // if gap is larg then  only one step can not stabal voltage
      adc_read();
         if(main_v>2410)
               {step--;  if(step<1)step=1; relay_set();}     //239V
                   else if(main_v<1630)                      //200V
                     {step++; if(step>6)step=6;relay_set();}
                        else;
   while((main_v<high_limit)&&(main_v>low_limit));  // check  the limits
/////////////////////under over section///////////////////////
   fault=1;
         time=0;                                          // reset timer if it was running
         if(main_v>=high_limit)         main_high();      // call  relevent function
            else if(main_v<=low_limit)     main_low();    // call  relevent function
               disable_interrupts(int_timer1);            // reset timer and interrupt
                           fault=0;
   enable_interrupts(int_timer1);
       enable_interrupts(global);
         off(relay4);
            off(relay3);
               off(relay2);
                off(relay1);
                  delay_ms(500);
                  while(main_v<low_ok)
                        time=0;
                           adc_read();
         off(relay4);
            on(relay1);
               on(relay2);
                on(relay3);
                  delay_ms(500);
                     while(main_v>= high_ok)
                         time=0;
                               adc_read();
   delay_ms(20);
      main_v =read_adc();
         main_v=main_v*5000/1023;
 void    initialize  (void)
   off(relay4);
      on(relay1);
         on(relay2);
            on(relay3);
/////////////input output setting////////////////////
   set_tris_a(0b11110001);
      set_tris_c(0b11111000);
         output_float(pin_a0);
            setup_adc(adc_clock_div_64);
               SETUP_ADC_PORTS(sAN0 ) ;
   delay_ms(100);
      adc_read();
         setup_timer_1(t1_internal | t1_div_by_8);
               set_timer1(65536-62500);                  //initialize for correct time
                  enable_interrupts(global);                //unmasked interrupts enable
  void   relay_set   (void)
if(step==1)
 { on(relay1);
   on(relay2);
   on(relay3);}
   else if(step==2)
        {on(relay1);
         on(relay2);
         off(relay3);}
      else if (step==3)
           {on(relay1);
            off(relay2);
            on(relay3);}
          else if (step==4)
               {on(relay1);
                off(relay2);
                off(relay3);}
             else if (step==5)
                  {off(relay1);
                   off(relay2);
                   on(relay3);}
                else if (step==6)
                     {off(relay1);
                      off(relay2);
                      off(relay3);}
                     else;
              ----v----
       +B < 1 |       | 14 > -B
   #include	<16f676.h>
   #device     adc=10
   #fuses      intrc_io
   int1           fault=0;
   #int_timer1
        time++;
         output_toggle(led);
                     on(led);
                        on(relay4);
   void  main()
   initialize();
   WHILE(1)
       start_up();
   do
      adc_read();
         if(main_v>2410)
                        else;
   fault=1;
                           fault=0;
         off(relay4);
            off(relay3);
               off(relay2);
                off(relay1);
                  delay_ms(500);
                        time=0;
                           adc_read();
         off(relay4);
            on(relay1);
               on(relay2);
                on(relay3);
                  delay_ms(500);
                         time=0;
                               adc_read();
   delay_ms(20);
      main_v =read_adc();
   off(relay4);
      on(relay1);
         on(relay2);
            on(relay3);
   delay_ms(100);
      adc_read();
if(step==1)
 { on(relay1);
   on(relay2);
   on(relay3);}
   else if(step==2)
        {on(relay1);
         on(relay2);
         off(relay3);}
      else if (step==3)
           {on(relay1);
            off(relay2);
            on(relay3);}
          else if (step==4)
               {on(relay1);
                off(relay2);
                off(relay3);}
             else if (step==5)
                  {off(relay1);
                   off(relay2);
                   on(relay3);}
                else if (step==6)
                     {off(relay1);
                      off(relay2);
                      off(relay3);}
                     else;
i change ur code s my pcb .
those change re s below
PHP:
          O = Output, I = Input
                    _________
              Vdd   | 1  14 |  Vss
  (I) SW1 --> RA5   | 2  13 |  AN0 <-- ADC_Value (I) For O\P feed bauck
  (I) SW2 --> RA4   | 3  12 |  RA2 --> RL1 (O)
             MCLR   | 4  11 |  N\C
  (O)  L1 <-- RC5   | 5  10 |  RC0 --> RL2 (O)
  (O)  L1 <-- RC4   | 6   9 |  RC1 --> RL3 (O)
  (O) BZR <-- RC3   | 7   8 |  RC2 --> RL4 (O)
but relay doing tik tak tik tak sound .
only 1 step work fine
step 6 & when i increas i\p volt . mcu sence step 5.
then relay doing tik tak tik tak sound .
There is only 4 relays. Other is LED (rc4) and it starts blinking when out of range. If you connect a relay to this pin, it will start to do "tic tic".
