T
treez
In a UK/European/USA domestic home, is the actual switch in a wall light-switch in the Live or the Neutral wire, or both?
how?? could u elaborateIf you put the switch in the neutral then the lamp socket contacts are live even when the switch is off, I am not seeing much safety improvement there.
Disha Karnataki, consider what happens if more than one lamp is wired in parallel, for example two ceiling lights on one switch. If the neutral is broken by the switch, the phase (live) wire is still connected directly to one side of the lamp socket and via the low resistance of the other lamp to the other side of the socket.
Yes, you are right, should be covered by IEC 60364-4-46.In Italy this is ruled by the 64-8 technical rule, that is given from an IEC rule.
So I think this is the same for all the world.
