monopole characteristic.
vishal_sonam
Full Member level 3
what is the meaning of monopole characterictic in any antenna? I have seen many papers which say monopole antenna but I don't know how to check this characteristic if the antenna is monopole or not. So kindly tell me what is monopole antenna
So, monopole antenna is half of the dipole antenna, with right ground.
so you mean almost all the antennas which partial ground plane are monopole antennas?
I have no time for explanation. If briefly , exists at all two variants, direct wire type dipole or named simply symmetric structure if you wish and slot approach same symmetric and non symmetric structures like modification of symmetric as well. On the pictures you can see both. It is briefly, I hope it will be enough for you.
what do you mean by right ground?
it means big enough like big bambulll...:wink:
