ADGAN
Full Member level 5
Need some facts about GSM modems
Hi! I need a GSM modem ONLY to send a SMS. SMS contains a numerical value. Which mode should I use text mode or PDU mode? This is the GSM modem I'm hoping to use in my project
Is it possible to send a messages from the microcontroller without using the serial port instead using the RX TX pin. It says it support serial R232 and TTL. So do I require a MAX232 IC ?
Is there any other model which does not come with a serial port & a power connector ? Since I'm hoping to produce a compact design for the project I prefer to have a GSM modem which does not have a serial port & a power connector
