how to use the PML in Hfss?
antenna
Newbie level 6
Newbie level 6
hfss pml
I am studing Hfss,but i dont know how to use the PML ,anyone can give me some infomation about it .
thx.
pml hfss
For the new user (unexperienced with hfss) Ansoft has implemented automatic setup of the PML . One may also build its own PML boundaries but it calls for a bit (sometimes alot) more skills and some trivial calculations beforehand. I'd suggest that you read the manual - PDF version and look at setting up the PML boundaries. You must have macros installed though to make use of it, for hfss is calling a macro to do the dirty job of defining the PMLs. After you're done you must define the PML material properties in the Materials Manager by invoking PmlMatSetup macro. It is very intuitive and easy to set. Should you get in troubles ring the bell:).
cheers,
pmlcoversetup
While on the topic, can anyone give some experience on the performance difference between PML and the "old" radiation boundary in HFSS?
pml+hfss
pml in hfss
Hi cheng,
thx for your help.it is a new puzzle in define the thickness of the layers after invoking pmlcoversetup . I set it freely(>0), i dont know its true or false. the other question is how long does the pml locate away from my antenna.
rgds
lee
pml macro
Hi Lee,
The fact is that the user himself will determine the size of the region enclosed by the PMLs. When you set it up you enaclose the existing structure by the BASE box - with size defined by you and the software calculates the distances between the structure's outermost x-, y-, and z- direction and your PML Base box. The smaller the distance, the more layers the software adds and the more wild and narrowband the PML gets.
Hope it helps
rules to set pml in hfss
Hi cheng,
i see. i will learn morn about it . thank you very much!
regards
lee
