define a transistor in cst with s2p file
amntt
Full Member level 1
any one knows , if i can simulate a transistor in cst design and use its s2p file such as what we do in ads
you mean how to load a S2P file in ADS?
No problem in CST design studio.
i want to use renesus ne 3210s01 in my design (in cst) but i dont know how? i should use its s2p file or it is defined somewhere in cst library?!
@ CST library are spice par. Much better and accurate use like box s2p. Otherwise transistor is good and cheap, below 1$. Only for attention, exists not correct s par for these transistor. For example s21 grooving ( excitation in a dut )above 20GHz and so on. It should be monotone and logic curves. We made some device up to 40GHz.
Reactions: amntt
    amntt
