What does "far" in BYTE far *Temp; mean?
SphinX
Advanced Member level 3
EGYPT
Salam,
         BYTE far *Temp;
         Temp  = (BYTE far *)0xA0005555; /* set up address to be A000:5555h    */
         *Temp = 0xAA;                            /* write data 0xAA to the address     */
Please what does "far" mean here ?
Re: BYTE far *Temp;
Far, means that the pointer is double word address, insted of word. So you can point more than the segment your are working. (generaly Data segment).
    SphinX
Re: BYTE far *Temp;
Hi
Far prefix mean that a variable declared have a size of LARGE MODE in memory mode.
if you selected LARGE MODE in memory mode then Far don't need.
Far only use when select COMPACT MODE or SMALL MODE but use LARGE MODE for a variable.(MIXER MODE)
Re: BYTE far *Temp;
in small memory model pointer only poins to offset inside the segment but in far
pointer both segment and offset are stored .this is only in 16 bit compilers.
