[SOLVED] Problem in RFID Hardware Connection
vinothksr08
Member level 3
Member level 3
Tamilnadu, India
Hai friends
am doing door accessing system using RFID. I have problem with hardware connection. i have RFID Reader module that i have attached in image. i don't know how to use that module with microcontroller board. can anyone help me
i can get output when i directly connected with PC Serial port.
than you people....
hai jinzpaul
I have completed my coding section. i cant get output in hardware.. i couldn't receive data from RFID module., am sure there is no problem in RFID Module. i think there is a problem in communication between RFID & Microcontroller. i don't know exactly whats the problem. can u explain??
thnaks
Hello there,
Try RFID with PC Hyper terminal and MCU with Hyper terminal ..check the output is coming or not?
Update me.
Best regards
check circuit here
Check the circuit here
  • Circuit to interface GSM Module with 8051 microcontroller (AT89C51) using PC and LCD circuit.gif
Please Post your code here,
Which MCU are you using ?? compiler??
Have tried to send a byte of data from hyper terminal to MCU?? check your Hardware connection fully. verify your receiver code with Hyper terminal
Update me
i am using at89c51... am sure about my code there is no error in this code... i have checked all my simulation in hyper terminal... but i don't know what to do with that module i attached earlier... please help i attaching my code also
#include<reg51.h>
sbit output=P3^0;
void door_open();
void lcd_command(unsigned char comm);
void lcd_data(unsigned char disp);
unsigned int data_out,command=0x80,temp;
sfr lcd_data_pin=0xA0;
sbit rs=P1^0;
sbit rw=P1^1;
sbit en=P1^2;
unsigned char card_id[12];
unsigned char current_byte = 0;
void delay(unsigned int count)
     int i,j;
     for(i=0;i<count;i++)
     for(j=0;j<1275;j++);
void lcd_command(unsigned char comm)   //Lcd command funtion
     lcd_data_pin=comm;
     en=1;
     rs=0;
     rw=0;
     delay(1);
     en=0;
void lcd_data(unsigned char disp)  //Lcd data function
     lcd_data_pin=disp;
     en=1;
     rs=1;
     rw=0;
     delay(1);
     en=0;
lcd_string(unsigned char *disp)     //Lcd string function
     int x;
     for(x=0;disp[x]!=0;x++)
         lcd_data(disp[x]);
void lcd_ini()                  //Function to inisialize the LCD
    lcd_command(0x38);
    delay(5);
    lcd_command(0x0F);
    delay(5);
    lcd_command(0x80);
    delay(5);
void display()     			   // Function to display the unique id
    unsigned char count;
    lcd_command(0xC1);        //Place cursor to second position of second line
    for(count=0;count<12;count++)
          lcd_data(card_id[count]);
    current_byte=0;
void compare()
int m;
for(m=0;m<12;m++)
if(card_id[m]=='a' && card_id[m+1]=='b' && card_id[m+2]=='c' && card_id[m+3]=='d' && card_id[m+4]=='e' && card_id[m+5]=='f' && card_id[m+6]=='a' && card_id[m+7]=='b' && card_id[m+8]=='c' && card_id[m+9]=='d' && card_id[m+10]=='e' && card_id[m+11]=='f'
|| card_id[m]=='1' && card_id[m+1]=='2' && card_id[m+2]=='3' && card_id[m+3]=='1' && card_id[m+4]=='2' && card_id[m+5]=='3' && card_id[m+6]=='4' && card_id[m+7]=='5' && card_id[m+8]=='6' && card_id[m+9]=='7' && card_id[m+10]=='8' && card_id[m+11]=='9')
display();
door_open();
void door_open()
lcd_command(0x01);
lcd_command(0x84);
lcd_string("WelcomE");
lcd_command(0xC0);
lcd_string("The door opened");
void recieve() interrupt 4
          card_id[current_byte]=SBUF;
          RI=0;                // Reset the serial interrupt after recieving the byte
        current_byte++;
void main()
	output=0;
   TMOD=0x20;                            //Enable Timer 1
   TH1=0XFD;
   SCON=0x50;
  TR1=1;
   EA=1;
   ES=1;                                // Trigger Timer 1
   lcd_ini();
   lcd_command(0x81);                    //Place cursor to second position of first line
   lcd_string("UNIQUE CARD ID:");
   delay(200);
    while(1)
        while(current_byte!=12);
		compare();
thank you..!!!
Hello there,
Are you trying this code?? **broken link removed**
i have uploaded the c code for interfacing 8051 and RFID
  • rfidprojectccode.zip
There is a problem with the condition here. I guess the operator precedence will create a problem for you.
Put both your conditions in parenthesis before you OR them.
if((card_id[m]=='a' && card_id[m+1]=='b' && card_id[m+2]=='c' && card_id[m+3]=='d' && card_id[m+4]=='e' && card_id[m+5]=='f' && card_id[m+6]=='a' && card_id[m+7]=='b' && card_id[m+8]=='c' && card_id[m+9]=='d' && card_id[m+10]=='e' && card_id[m+11]=='f')
|| (card_id[m]=='1' && card_id[m+1]=='2' && card_id[m+2]=='3' && card_id[m+3]=='1' && card_id[m+4]=='2' && card_id[m+5]=='3' && card_id[m+6]=='4' && card_id[m+7]=='5' && card_id[m+8]=='6' && card_id[m+9]=='7' && card_id[m+10]=='8' && card_id[m+11]=='9'))
I guess it should work.
Thank you very much friends especially for Jinzpaul....
i got output in hardware for my same code......
Did you figure out what was the problem...??
You can share it here so that, if in future if someone searches he can get useful guidance.
Yaah sure my problem was with my RFID Module... in that module i have to received data from TTL pin & i should connect Male to male DB9 Connector between controller board and RFID Module... till now i didn't do it... now i only i found that
