MPLAB 8.85 problem PORT SETTING AS INPUT
Noman Yousaf
Full Member level 4
Full Member level 4
Lahore Pakistan
i m using MPLAB 8.85.
can anybody tell me that how can i use or change the state of ports my self? is that possible or not.
i just wrote a program to turn on an led by making a port hi but when i make the port line hi, in "SFR register" window it goes lo itself without any action. i m sending the code and screen short of the mplab screen. MPLAB_SCREEN.JPG
SOFTWARE IS AS FOLLOWS.
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
LIST   P=PIC16F676
                PROCESSOR  16F676
                #include "P16F676.INC"
        __CONFIG   _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
;THIS IS SIMPLE SOFTWARE TO TURN ON THE LED (PORTC,0)BY CHANGING THE PORTA,5
                ORG             0
                        IN_SW   EQU             5               ;PORTA,5 AS INPUT
                        LED             EQU             0               ;PORTC,0 OUTPUT
                        BSF                     STATUS,RP0              ;SELECT BANK1
                        CLRF            TRISC                   ;MAKE PORTC OUTPUT
                        MOVLW           0FFH                    ;MAKE WREG 0FFH
                        MOVWF           TRISA                   ;MAKE PORTA INPUT
                        CLRF            ANSEL                   ;MAKE ALL ADC LINES AS DIGITAL INPUT
                        BCF                     STATUS,RP0              ;SELECT BANK0
MAIN
                        BTFSS           PORTA,IN_SW
                        GOTO            MN1
                        BSF                     PORTC,LED
                        GOTO            MAIN
MN1
                        BCF                     PORTC,LED
                        GOTO            MAIN
        END
When the PC is pointing to 1st instruction in MAIN then you have to set PORTA as 00000001 in SFR window. Also see if you can see IN_SW in variables window. Try to set it there. For better help zip and post your mplab project files.
File is attached
please note that porta,5 is input.
  • TEST_IDE.rar
File is attached
You need to use Mplab, Debugger , Stimulus - a simple example is shown with your code in the screenshot.
Just Step though your code and Fire the change to pin RA5.
See Mplabs Help, Mplab Sim , Stimulus.
This link is also helpful
