What is hot nwell in Cadence?
sisching
Junior Member level 1
I am drawing the layout by Cadence.
After the DRC, there are some warnings. "Hot nwell"
How can i solve this problem.
cadence hot nwell
which tool r using ?ic5033 or custom virtuso or other?
hot n-well
Usually, hot n-well in nwell that is not connected to VDD.
You should check that the Nwells are connected correctly to VDD. If you want to connect the nwell to different potential,I think that you can ignore the warning.
    kdeleon
hot nwells
"hot nwell" is the well that's left floating or say not connected to vdd. this could result in a forward biased pepi-nwell junction, which in trun could lead to latch-up.
Re: hot nwells
There are two things here ..
1. Cold Well
2. Hot Well
Cold Well : refers to the N-well in which we connect the Bulk to Vdd rail .
Hot Well : refers to the N-well in which we connect the Bulk to another source/drain .. but not to Vdd / Vss
Hoe this helps ...
Maaz
    kdeleon
