Help Arduino Program
brian25
int pinA = 11;
int pinB = 12;
int val;
void setup()
pinMode(pinA, OUTPUT);
pinMode(pinB, INPUT);
void loop()
int();
void int()
val=digitalRead(pinB); // read data
if(pinB == HIGH)
Serial.println("PINA ON"); //write serially
else if(pinB == LOW)
Serial.println("PinA OFF"); //write serially
the message is keep repeating. how to stop the message in serial monitor even the pin is still in continuous active high or low status. it's just a one time message.
for the solution of this u can use goto statement and let the arduino wait for command
check this out i have rewritten the code with ur requirement
void int()
one:
if(pinB == HIGH)
goto two;}
else
{goto one;
two:
if(pinB == LOW)
goto one;}
else{goto two;}
by this way the seriel message will be printed only once
Reactions: brian25
    brian25
