neazoi
Advanced Member level 6
Hello I have an application that uses the logic attached.
The write switch, writes the contents of some registers to the memory, when the left switch is switched in the program position and also in the run position.
Is there any way to prevent the write switch from accidentally being pressed, when the left switch is in run mode?
