How to design Balun transformer
yuhohang
Junior Member level 3
balun design
Dear All
Anyone have the experience to design a balun transformer to convert the differential port to single port?
Moreover, how to measure the diffential port impedance with 2 port network analyzer?
Best regards
yuhohang
balun designs
To do measurements you will need another balun to bring the impedance back dowo to your other port. You have two choices. The first is to use a laboratory quality one that is available from the anazyer manufacturer. The other is to use two. Put an attenuator between the balanced prorts. When you do the S12 and S21 measurements, subtract the attenuation and divide theresult by two to get the parameters of just one balun. The S11 and S22 measurements are correct as is. Of course, you need a good attenuator which you will have to be careful in designing and constructing and be at the impedance level of the balanced side.
balun transformer
I've seen a good explanation about the subject in the 2002 ARRL
Handbook.
Bye. :) :)
double y balun
Tornado,
Thanks for the good links.
g579
designing baluns
Please check the ARRL publication:
Transmission Line Transfomers by Jerry Sevick W2FMI
ISBN 0-87259-046-1
I think it is at it's second printing (at least)
This is a very down to earth explanation how to design and measure Baluns and impedance transformers from 0.1 to 100 MHz
It's a MUST HAVE book! :D
Cheers
WD
how to gesign an balun
Your link does not exist. If you have the apnote upload it.
Thanks.
Bye. :roll:
baluns transformer
Hi, :roll: :roll: :roll:
Take note if another balun is adopted. Proper de-embedding is needed.
three balun designs for push-pull amplifier
Thanks.
Bye. :roll:
It exists, here it is.
sevick transformer note 2001
Please look at:
h**p://www.ctsystemes.com/zeland/publi.htm
There are a lot of publications (and benchmarks)
about i@e@3d. Among other there is an article:
h**p://www.ctsystemes.com/zeland/publi/pg40.pdf
(A wideband balun-how does it work)
harlan1
wideband balun, how does it work
Terminate the primary in the design impedance. Then port 1 of network analyzer to one lead of secondary and port 2 to the other. Take the S-Parameter and put them in your favorite RF analyzer. Then terminate it with a floating termination. Its a snap in @DS. I'm sure other analyzers can handle this, too.
how do baluns work
:) Any ports network(a balun can be it) can be simulated!
transformer, 4 port, deembedding
Here is another article discussion on balun:
Double-Y Baluns for MMIC and Wireless Application.
design balun ads
While designing balun, what are the parameters to meet requirement?
S21, S11?
