JesterBR
Newbie level 5
Hi everybody!
I am having problems to use a P-Channel mosfet. I've made a circuit using a N-Channel Mosfet(IRF640) and another CI to switching(Til113 with the signal coming from a PIC). The circuit works fine but I noticed that it wasn't so efficient. Now I am trying to use the IRF9640 with TLP250.
I have a source of 180(15~180 using capacitors) and I need to keep a brush motor DC with constant voltage of 24v(after I am going to work this voltage that will vary from 0 to 24V).
I already written the code and built the hardware to read the Vin(15~180) so I can work with the PWM signal.
My problem is: P-Channel mosfet doesn't work with a 15V input gate and Source of 180V. After searching a lot, I read that the solution of my problem is using a 'Totem-pole Switching Circuit'(http://www.irf.com/technical-info/appnotes/an-940.pdf).
Sadly I didn't understand exactly how it works, and I don't even know from where should I start.
Could someone help me?
