myfaithnka
Hi all,
This post is the continuation of the a similar post.
So i am trying to charge a 6V battery from solar panel (12 V/5 Watt).
I am using the classic transistor 2SC1061 to control the charging. To turn off this at full charge i have included a IC NE 555 control(IC LM7809 to create exact reference voltage for trigger and threshold too).
Here comes the problem,The sun. let me explain,most of the time the charging doesn't happen because there is no enough voltage( or power) to drive the circuit. The charger behaves mysteriously when low light happens an Vref of 555 decreases and thus it turns the ckt off.
So i have an idea, a boost circuit. that is a constant voltage(12 V,varying current).
I have tried a joule thief with a zener (12 V ) shunt at output,only problem is the result at high light is depressing ( 500 mA input and gives only 20 mA to the battery !!!).
So what do you guys suggest, I just want a circuit which does its best at all times.
Next month rain starts here, so its going to be lot cloudy here.
Pls help.
Pls help.
