metRo_
I need to measure a potentiometer value from a joystick. The usual way to do this is to use it as a voltage divider.
But I remember from university that I use a constant current source to measure the potentiometer value but I couldn't remember the advantages of that application beyond this way if the power source varies I still get the same value.
Could you explain me if that application will give me best results? per example about noise?
PS: I'm thinking to use a lm334
